Random D1 and Offroad stuff so I stop thread-jacking
Who put it in?
Get a Torque Wrench yet?
For sure, the all terrains handle better than the mt's. the mt's look great and i'm sure will perform better off highway but i've lost some "tightness" with the mt's. my other vehicle is a D2 and the differences are confusing at time. window switches rearranged, totally different engine/cooling system. a bunch of parts exactly the same. it's hard for me to notice slight differences...some guys have that feel. i don't.
my guy. i got a guy for everything down here. wasn't easy but steering and suspension all new and super tight. crappy steering box leaks.
no torque wrench yet. i'll get it 10 minutes before I need it or buy this Craftsman set i've been looking at on craigslist.
I am probably about to ask a stupid question that has been covered a "million" times, but my search-fu is failing me (I have tried)..and this is my randomness thread anyway.
So anyway, what is the deal with putting D2 fender flares on a D1? Will they be big enough to go with 235/85/r16 tires...or would the flares themselves still need to be trimmed? My friend found some in a junk yard, and it seems like if I am going to have to trim the fenders anyway, it might not hurt to have some flares to make it look a bit cleaner...but if I would have to trim the flares as well it would sort of be counter-productive.
I know it wouldn't be required for that size tire...but a camel cut is...so I was thinking if they would "hide" the camel cut (in case I mess it up), but still have room for 32's they might be a valid option.
IMO 235/85/16's on stock rims will look silly with the D2 flares. But yes, they would hide a messed up Camel Cut. Go slow and take your time. Measure a bunch and cut a little. Cut more if needed. Get a set of ramps. Put them at opposite wheels, drivers front and passenger rear for example. Drive up the ramps and see how much you need to cut. You probably won't need any taken off the front. The rear you'll need to take about 2" off the bottom and taper it up into the arch.
When I did my Camel Cut it was the first "customizing" I did to my beloved Disco. Once you get dents and dings and pinstriping you'll look back and laugh that you were so concerned about cutting a little aluminum.
Oh, and use a air cut off wheel of angle grinder with cut off wheel. I find the action of a Sawzall to be too intense and the whole fender starts shaking.
I don't mind dents/dings/scratches that originate offroad...I just don't like the idea of messing it up while in the driveway.
My previous 4x4's got pretty beat up offroad.
How do you do a camel cut? Like is there a write up somewhere? I googled and cannot come up with anything..
It gets tossed around and I've asked before but people just say its trimming the rear fender. But where? How? Exact measurements or something? I think I found something on DWeb I haven't read it yet though..
Do like I suggested. Place ramps at opposite tires and drive up on them. It will become abundantly clear what you need to cut. Mainly behind the rear tire. Get a firm and flat piece of cardboard. Cut it into a long slightly curved line. Put it up to the back of the fender and move it around to the position that gives the smoothest transition. Trace the line with a sharpie. Now you have a template for the other side.
