Rear bumper lights?
Old Dec 17, 2010 | 10:10 PM
kevlor80's Avatar
Default Rear bumper lights?
My new 95 Disco (base model) didn't come with the operators manual so Rave has been excellent in solving most of my questions. The rave describes the bumper light cluster as directional light and a tailight. Is it suppose to come on with the tailights higher up (because they don't) or is it a rear fog light of sort and/or is it on a different fuse than the others? The bulbs seem to be OK. Since I'm on this topic, the higher cluster contains; tailight, brake and backup correct?
Old Dec 17, 2010 | 10:40 PM
tweakrover's Avatar
yea, they are weird i've read that there were some models with turns in the tail lights but some models didn't get wired the same so the only turn signal lights were in the bumper. there is a spot in the tail lights for turn signals, I wired the bumper turns to the tail light turns, cause I couldn't figure out why they didn't work. it wasn't til later that i found the weird enomily that left certain models without the tail light turns.
Old Dec 17, 2010 | 10:45 PM
kevlor80's Avatar
Yes, I had the main cluster out and thought I remember an extra bulb there also. May be possible to wire them all up. Less chance to being rear ended......maybe.
Old Dec 17, 2010 | 10:52 PM
tweakrover's Avatar
yea I found the wire for the extra bulb in the tail cluster and connected it to the wire for the bumper turns. they are both in the wire bundle that goes down by the tail lights. I can't remember if I cut the wire for the extra bulb to splice it to the bumper turn wire or left it intact and spliced them. here is where I read about the lights http://en.wikipedia.org/wiki/Land_Rover_Discovery
Old Dec 17, 2010 | 11:57 PM
kevlor80's Avatar
Appreciate that info.....if they are there, why not use them.
goatman
Mar 30, 2020 08:54 PM
Drillbit
Aug 17, 2015 12:32 PM
bcolins
Jun 22, 2013 08:55 PM
LRD2&ME
Nov 23, 2011 09:44 PM
mherson
Apr 26, 2010 05:50 PM
