rear diff spacer
Old Sep 9, 2010 | 01:46 PM
NiteTrain's Avatar
Default rear diff spacer
does this spacer really belong in the rear diff? manual doesn't mention rear having one..just the front. With it there my drive flange isn't able to mesh but 1"
Old Sep 9, 2010 | 02:11 PM
okdiscoguy's Avatar
pretty sure that spacer is for the 4 point flange. I have that one, as I do not have a rotoflex. I assume you are working on a 96 with a rotoflex coupling, in which case, I don't think it goes in there.
Was it part of a new bearing kit?
Old Sep 9, 2010 | 03:08 PM
antichrist's Avatar
There are two different 4-bolt input flanges. One requires the spacer and one doesn't.
Old Sep 9, 2010 | 03:40 PM
NiteTrain's Avatar
okdiscoguy, I didn't order a new pinion bearing..just a pinion seal..bearing seems ok. It's a '96 but theres no rotoflex, it has a U-joint.
antichrist, is there any way to tell which 4-bolt flange requires the spacer and which one doesn't?
what if somebody put the wrong flange on it? this rover was used for a off-road business and has been abused...so anything is possible.
Old Sep 9, 2010 | 04:59 PM
okdiscoguy's Avatar
I would take the spacer out and see how far back the drive flange goes on the seal. As long as it isn't rubbing wrong (too far in), I would say go without it.
Offroad company probably upgraded to the u-joint.. Didn't think they did that until the 97's.
Old Sep 9, 2010 | 07:06 PM
antichrist's Avatar
If with the spacer you have 1 1/2 threads or so exposed after fitting the nylock nut, then what's there is correct.
I think I had a brain fart. Looking in my parts book the spacer is used with the 4-bolt flange. 3-bolt doesn't use a spacer.
Old Sep 9, 2010 | 10:21 PM
Danny Lee 97 Disco's Avatar
I have an "Early" 97, manufactured in mid 96 according to the stickers on everything, and mine has the rotoflex.
Old Sep 9, 2010 | 11:24 PM
NiteTrain's Avatar
I think the PO did this conversion to my disco
http://discoweb.org/rotoconversion/index.htm
Old Sep 10, 2010 | 07:56 AM
okdiscoguy's Avatar
You can buy a kit from roverparts.
Spencerfitch
Feb 2, 2011 10:08 AM
oysterhead
Apr 12, 2010 08:42 AM
Discoverydiesel2003
Oct 29, 2007 08:23 PM
97DISCOIDAHO
Mar 16, 2007 11:35 AM
kaczman
Feb 4, 2007 04:22 AM
