Rear differential flange/seal replacement
Old Sep 21, 2025 | 12:18 AM
Juaco112's Avatar
Default Rear differential flange/seal replacement
Hi all,
im stuck with rear diff flange bolt, i feel ill shear it if i keep trying to loosen it. I’ve searched in the forums but people refer to 3 bolt flange, well mine has 4 bolts and that bolt in the middle is super tight.
how can I loosen it up? I tried mild heating but read somewhere the thing needs to be live red?????
Old Oct 21, 2025 | 11:05 AM
ColtenM1's Avatar
I'm converting to the 4 bolt flange as we speak. But mine was pretty easy to get out. Not by hand but with anelectric impact. Whatever you do just make sure you have the wheels chocked off since you have the axel disconnected the back wheels are free to move with you underneath. However you can use that to your advantage, and roll the car to a position where your breaker bar has better leverage.
I Brake For Cats
Sep 1, 2020 10:40 PM
cybercop
Aug 31, 2015 04:08 PM
Charlie_V
Aug 29, 2015 12:59 PM
Danny Lee 97 Disco
Jan 27, 2011 09:32 PM
martyn
Sep 2, 2007 09:14 AM
