Rear drivers side window stuck down?
Hi everyone,
I recently noticed my rear driver's side window stays down, and when I use the switch to raise it, nothing happens, other than some weird sounds.
What could have happened? Motor? Rail? Something loose?
Regulator failed. Pull the door panel and likely your wheel broke off and the arm isn't in the track anymore. That's an easy fix, go to home depot or Lowes and get 1" nylon washers and use those. I ended up drilling out the rivets on mine and using the bolts and roller for a screen door.
Thank you sir
Just happens to have started raining today, and no duct tape! Home Depot tomorrow
twoxred
Oct 4, 2021 07:07 AM
Mike B.
Nov 12, 2012 05:20 PM
