Drivers window wont go down
Old Oct 19, 2008 | 03:24 PM
baysiderover's Avatar
Default Drivers window wont go down
It will only go down intermittently and up works all the time. When the window is up and you push the switch up you hear the moan of the motor, but when you push the switch down you hear nothing. Eventually down starts to work again – once or twice, the stops.
I changed the switch – no improvement. I took off the door panel and disconnected the motor switch and put a tester on the power that comes from the door jam. The results were as expected, up had power every time and down had power intermittently.
Last year I did the re-solder fix for the rear windows and I replaced the window regulator on the drivers door because the plastic roller broke. This one has me stumped.
Any suggestions?
Thanks
Old Oct 19, 2008 | 05:09 PM
Default RE: Drivers window wont go down
Man this is a tough one, maybe you need to re-solder the front part of the window ECU?
Other than that I've got nothing. Very weird.
Old Oct 20, 2008 | 10:22 PM
tacomatech's Avatar
I would check for a backed out pin, pinched wire, chafed wire, any kind of intermittent open circuit.
Old Oct 21, 2008 | 09:10 PM
Jst4fun's Avatar
Intermittent electrical problems are some of the most difficult to resolve.
My only advice would be carefully check local grounds, connector cleanlyness, and previous solder work. A cold solder joint could reak havock. Good luck!
Regards,
Nick
Old Oct 28, 2008 | 08:06 AM
Just an update to anyone that may have this problem in the future. Resoldering the board behind the glovebox fixed the problem. Thanks everyone.
Michael Paragios
Jul 17, 2014 09:22 PM
archaeology_student
Oct 30, 2013 09:33 PM
jbunner
Jun 5, 2012 08:48 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
AndrePlav
May 19, 2010 12:17 PM
