Rear hatch won't open from outside
Old Jan 26, 2011 | 11:13 AM
DiscoIIBrandon's Avatar
Default Rear hatch won't open from outside
I can only open the rear hatch from the inside by lifting up on the lock while pulling the handle...it gets a little old after a while!
Anyone else have this problem that can lead me in the right direction?
As always, thanks in advance...
Old Jan 26, 2011 | 11:47 AM
groundandpound's Avatar
Pop off the Land Rover emblam on the external handle. Then clean and lubricate the mechanism that is exposed - that should resolve your issue!
If not - it should expose the component that is in need of repair.
Good Luck!
Old Jan 26, 2011 | 11:48 AM
Good Luck!
I've read about doing this and wondered if it might help my problem. What do you recommend for cleaning and lube for this?
Old Jan 26, 2011 | 12:08 PM
I used a stiff nylon brush to get most of the crap off mine, compressed air to finish up.
For lubrication - graphite - anything else will attract dirt and dust and cause you to re-do this again and again.
If you dont mind doing it again and again, WD-40 worked on a friends who refused to wait for me to bring the graphite to him!
Let me know how it goes!
Old Jan 26, 2011 | 12:10 PM
Sounds good. That is the 2nd shout-out i've gotten for graphite! I will let you know...hopefully soon.
Old Jan 26, 2011 | 12:17 PM
hilltoppersx's Avatar
i use silicon based products . you may need to work the handle for a minute or so and keep spraying it.
Old Jan 26, 2011 | 12:39 PM
I completely agree on the need to "work it" to get it functioning again.
Have you had any build up issues with the silicone sprays?
Old Jan 26, 2011 | 01:57 PM
negative. i have with other petreoleum based lubricants.
Old Jan 26, 2011 | 02:00 PM
Gotcha.
Thanks for the info! Sometimes the graphite can be hard to come by. Glad to know there is an alternative (cheaper to boot) that does not carry the negative consequences the petroleum products do.
MUCH appreciated Top!
Old Jan 26, 2011 | 04:54 PM
Chris-bob's Avatar
I find the silicon functions better in the wet cold environment I live in than graphite does.
