rear QT diff & weight
Old Mar 3, 2012 | 06:30 PM
JamesDisco97's Avatar
Default rear QT diff & weight
So I had thought that I was sent the wrong rear QT diff guard because when i went to install it the thing was hitting the flex joint. I thought the end was supposed to be round to accommodate this.
I gave up till it got warmer.
Well I decided to have another look and after browsing the forums there seems to be a weight that sits under the rear diff that the PO must have removed. I'm assuming that with this weight the space of the mounting plate will allow the diff guard to clear the flex joint.
Does anyone know if the 97 D1 does in fact have this weight?
If i can't find one (i'd rather have it there if its meant to be there) I'll just fab a steel spacer to get the diff on.
Any thoughts?
Old Mar 3, 2012 | 06:56 PM
ptschram's Avatar
No, your '97 DI did not have the harmonic dampener on the rear axle.
That said, I don't think the QT diff guard will work with the rotoflex due to interference.
Old Mar 3, 2012 | 07:41 PM
hmmm. Time to call Lucky 8 i guess.
I'll try a spacer first and if i cant return and trade it ill just refab the end where it hits.
Thanks for the reply!
Old Mar 4, 2012 | 09:04 AM
It works well on my D2 with a a rotoflex.
Old Mar 4, 2012 | 11:04 AM
Yea Mike I'm at a loss here and I had a feeling that you would say that. If you have the time could you post a pic of yours. It's such a simple thing I don't know what is going on.
Old Mar 4, 2012 | 11:34 AM
turf63's Avatar
Dude, just call justin, you're either being stupid and dont see the answer, or it's not right and he'll make it right. Either or. BTW, im probably gonna have some one running up to buffalo and making a pickup for me around easter, so if you want to swap it out and save on shipping.....
Old Mar 4, 2012 | 11:41 AM
You don't get it. It's like a puzzle i have to sort out. I'll return it at a last resort.
Old Mar 4, 2012 | 01:09 PM
turf63's Avatar
Dork. I'll come over and fix it for you. Nothing a little heat and a hammer probably couldn't fix.
Old Mar 4, 2012 | 01:21 PM
smoker's Avatar
You guys are making me hungry... I recently moved south from SE PA. Now please go to Pat's and have one for me.
DavidG
Dec 9, 2016 03:34 PM
bosshogt
Aug 4, 2011 12:49 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
rrhyne
May 16, 2009 04:20 PM
