Rear TailLight Fuse Where TF is it???
Old Feb 20, 2011 | 02:26 PM
Mike_C's Avatar
Default Rear TailLight Fuse Where TF is it???
Ok, I've looked throught the owners manuel and could not find any fuse that was related to the rear tail lights. Meaning when the lights are on the rear tail lights do not work. I pulled mulitple fuses and checked everthing that says lights.
No luck...Is there something wrong with me (Ok clearly there is but be nice)
98 Disco 1
Old Feb 20, 2011 | 02:32 PM
tweakrover's Avatar
check bulbs
Old Feb 20, 2011 | 02:38 PM
Mike_C's Avatar
Replaced taillights and license plate bulbs...still a no go?
Old Feb 20, 2011 | 03:27 PM
tweakrover's Avatar
they are all under the steering wheel except the big fuses under the hood
Old Feb 20, 2011 | 04:32 PM
Backroadie's Avatar
4wd High
Default Interior Fuse
Rave Manual Section 86, Repair, page 1 shows the fuse box location and which fuse is used for the stop light bulbs...fuse 1. Good Hunting.
File Type: pdf
Old Feb 20, 2011 | 04:38 PM
Long Haul's Avatar
Also check the plug in the drivers side rear wheel well. The plug tends to corrode and loose connection.
Blakesrover
Feb 21, 2013 01:43 AM
Safari
Aug 30, 2011 04:47 PM
Classic89
Aug 21, 2007 07:53 PM
artcareer
Dec 23, 2006 12:35 PM
95DiscoSE7bullitt
Mar 12, 2006 12:50 AM
