rear view mirror problem
My 97 Discovery XD has a problem with the rear view mirror.The rear view mirror has lost all of its silvering. Can this be re silvered or does it require a full replacement? These are fairly expensive ($150). Thanks for any help. Mike
Go to any glass shop and have them glue on a GM rear view mirror button (mount), that will cost you about $10.
Then go buy a GM rear view mirror from anywhere you want, a junk yard, a auto parts store, anywhere and mount it up.
I am trying to replace my rear view mirror in my '98 Disc that has auto dimming & map lights with a newer model Rover mirror that has auto dimming & compass (couldn't find exact duplicate locally). Any ideas how to tell which of 3 wires in new mirror is hot, neutral, ground? The new mirror had no connector so had to cut the wires at junk yard & are different colors from old mirror. (The new colors are black, white/grn, grn/brwn if that is any help).
Thanks for any help
Thanks for any help
And if you get an 03-04 you'll get homelink too.... not sure how much work to hook all that up or if the mounts are exactly the same though.
PilotDoofy
Sep 20, 2007 09:10 PM
