Rear view mirror replacement?
Old Sep 22, 2012 | 03:46 PM
Britchick1980's Avatar
Default Rear view mirror replacement?
Hi! I'm new here. I just recently bought a 97 discovery. And I've just noticed that the rear view mirror is, basically, knackered. It is the auto dimming one and I've noticed the yellow fluid is not where it is supposed to be. Does anyone know what I can use as a replacement? I've scouted on eBay and found some. Most also have the yellow fluid present or they're expensive.
Old Sep 22, 2012 | 04:30 PM
ihscouts's Avatar
Limo tint the rear window or snag the "You Dim" rearview mirror. Even if you find a used self dimming it won't be long before it isn't. Too expensive to buy new for a vehicle that is worth as much as. Great concept poorly executed.......
Old Sep 22, 2012 | 04:42 PM
Snag the what?
Old Sep 22, 2012 | 05:12 PM
ihscouts's Avatar
The type that YOU have to tilt, prismatic.
Old Sep 22, 2012 | 08:26 PM
Oh right. Sorry. I'm a girl. What do you expect. LOL
Old Sep 22, 2012 | 08:30 PM
Rover_Hokie's Avatar
The old manual kind that seem to work better anyway, but I am old so, hey that may just be what I am use to.
Old Sep 22, 2012 | 09:08 PM
The DI uses a special type of mount for the mirror so no other will fit.
I bought a aftermarket mirror that uses a standard General Motors mount, you can do the same thing.
Go to the auto recycler and buy a mirror from a Ford or what ever and then have a auto glass repair shop remove your old mirror and mount the new one.
Dont worry about the auto dimming, just tuck those wires up under the head liner.
Old Sep 22, 2012 | 10:19 PM
98D1Chap's Avatar
I bought a mirror that clamps over the old one at Pep Boys. I like it because its a little bigger than the old one so it covers it completely and I still have the map lights under the original mirror that still work, which is nice. My back window has limo tint so high beams don't bother me.
Old Sep 23, 2012 | 06:49 AM
That's what I thought. But I wondered if one would fit from a discovery 2? I've found a replacement on eBay for $70 which I am considering. Either that or asking a friend back in Britain if they can find one at a junk yard. Not too many junk land rovers in my neck of the woods :-/
Old Sep 23, 2012 | 10:00 AM
The ONLY problem with that is the fluid inside the mirror is HIGHLY corrosive and eventually it will leak out and when it does it WILL eat your dash, stereo, cellphone...anything it comes in contact with.
