Was rearended yesterday.
Old Apr 5, 2017 | 03:40 PM
hrhoward's Avatar
Default Was rearended yesterday.
Coming to a stop doing about 15-20 or so. Fella behind me did not. His car, late model Nissan Versa, was fubar. He went right under the hitch. Wish I would of gotten a picture.
I did notice that the hazards came on and wouldn't go off until I turned the ignition off and back on.
Attached Thumbnails Was rearended yesterday.-accident-april-4th-2017-1-.jpg   Was rearended yesterday.-accident-april-4th-2017-2-.jpg   Was rearended yesterday.-accident-april-4th-2017-3-.jpg   Was rearended yesterday.-accident-april-4th-2017-4-.jpg   Was rearended yesterday.-accident-april-4th-2017-5-.jpg
Old Apr 5, 2017 | 03:59 PM
OverRover's Avatar
Wow that SUCKS! I'm shocked at the amount of damage (all things considers I know it's minimal) to the Disco from a POS Versa.
Just a heads-up, be sure to either you or the collision shop inspect the fuel tank really well. I had this type of accident with a RRC and the fuel tank skid plate split the plastic tank. It was a real PITA because the fuel tank only showed the leak when the skid plate was removed.
Old Apr 5, 2017 | 07:24 PM
Shiftonthefly1's Avatar
Hazards may have been inertia switch. Doing what it's supposed to be doing.
Old Apr 5, 2017 | 07:41 PM
ihscouts's Avatar
Did it fix the 50-60 rpm modulation?
Old Apr 5, 2017 | 10:29 PM
hrhoward's Avatar
OverRover, Thanks for the tip.
Shiftonthefly1, Gotcha. Read chassis manual and found there is an inertia switch in the alarm ecu. Engine never cut off. Was knocked into a muddy ditch and kept going for about 50 yards and got myself out. I hate mud.
ihscouts, No, surprisingly it didn't.
Old Apr 6, 2017 | 12:31 PM
OverRover's Avatar
" Nonetheless I tied a 2x4 to my posterior and carried on. "
OMG did you ever get LUCKY that you removed the 2X4 before you got rear ended!!!!!
Old Apr 6, 2017 | 12:36 PM
ihscouts's Avatar
You know we're gonna give em a complex if we keep this up.
Old Apr 6, 2017 | 01:14 PM
OverRover's Avatar
Let's hope not, but it could already be too late!!!!!
Old Apr 6, 2017 | 01:36 PM
hrhoward's Avatar
Aye, 'twas quite fortuitous that I removed the plank from my derriere prior to getting plowed from behind. The resulting circumstance would of been quite ghastly. The ramifications of what did transpire, from being run-through astern, was a trip through a heinous, noxious, befouled furrow most dank.
The likes of which I wish never to have my path darkened with again.
My complexion is quite clear, thank you very much.
Old Apr 6, 2017 | 01:37 PM
hrhoward's Avatar
Plank!!
