Relocate Airbag Diagnostic Control Unit -SRS
Gutting the interior completely out of my Disco and I've come to the Airbag Diagnostic Control Unit mounted under the console cubby. Does anyone know what that box does exactly? In other words, does it contain another crash sensor (current horizontal mounting) or is it just the box that fires the airbags after receiving a signal from the frame crash sensors? I want to relocate it to a less conspicuous location while keeping it still protected but I don't want an airbag in the mush.......and it's not really all the beautiful, the yellow harness and box is clashing with the curtains.......
Hey there IH, let's play nice here. I found your answer.
Airbag Center: Airbag Module | Airbag Resets | Airbag Light Repair
Airbag Control Module:
The airbag control module is also known as the airbag sensor, diagnostic unit, computer module, 591 and other names. They are mounted in different locations throughout the vehicle. Some common places are under the driver and passenger seat, center console, kick panel, under radios and behind the steering column. The airbag control module is good until a deployment occurs. However most modules can be reset.
Airbag Control Module Types:
During a collision the airbag control module receives information from the impact sensor, which then, relays a signal to deploy the airbags. The airbag sensor is then locked until it is either replaced or reprogrammed. Each vehicle can have many types of modules depending on which SRS features were equipped with the car. On start-up, the module checks the SRS system and reports any errors.
Yah there's no sensor per se inside the unit, let's just call it a router from the crash signal to the airbags so you should be able to mount on any axis.
Yah I'm pretty sure by the time the tech writers put the RAVE together they revolted as our vehicles are so idiosyncratic they'd be adding on the fly.
Bundu
Off Topic
38
04-13-2011 02:55 PM
