Reluctor tabs on drive plate
Old Indy ate another crankshaft position sensor. I removed the flywheel cover and found a reluctor tab had broken off and the reluctor ring is loose. I'm guessing that reluctor ring should be tight and have zero play?
If that's the case, I need a flywheel with good reluctor ring. Anyone on here have one for sale?
ChristianRover
07-29-2020 06:52 AM
