Remote oil cooler... Ideas?
Old Jun 29, 2010 | 12:10 PM
kingsly's Avatar
Default Remote oil cooler... Ideas?
I'm getting my radiator recored and at the same thing thinking about going with a remote oil cooler with more cooling capacity than the oil-coolant exchanger it's got now. I've heard that a proper cooler can reduce lower end temps by more than 40° and keep the engine much happier, since most engines run at way above optimum temps for the oil to achieve proper lubrication.
My problem is I can't figure out where to put it. I'm not sure if there's enough room between the ac condenser and the grill to fit one, and there's no way I'm going to mount one lower than the radiator or in the wheel arch, on errant rock on the trail and I'm done for...
Ideas?
Old Jun 29, 2010 | 03:01 PM
greg409's Avatar
Same here, I'm probably going to abandon the one in the rad, as trans temps can easily exceed 240deg.
Engine cooler, too.
If my wife would only ride in the jump seats, I'd put the important stuff next to me.
luck,greg
Old Jun 29, 2010 | 04:59 PM
kingsly's Avatar
Exactly, I'm thinking if anything the stock exchanger contributes to high coolant temps rather than helps them.
I toyed around with mounting the cooler in the hood, HMMWV style, but I can't figure out how I'd mount that either... Plus I worry a low pressure zone would exist and air would just woosh passed the cooler rather than through it!
Last edited by kingsly; Jun 29, 2010 at 05:05 PM. Reason: iPhone spell checker gone wild...
Old Jun 29, 2010 | 06:23 PM
I think you would have room behind the grill.
It's not that thick. (that's what she said!)
Old Jun 29, 2010 | 09:53 PM
jeffrudy's Avatar
i hear that one everynight..... thanks for bringing it up
behind grill or even tucked on frame rail. i had an old muscle car with one on frame rail and it worked swimmingly
Old Jun 30, 2010 | 03:25 PM
kingsly's Avatar
Where would you suggest on the frame where it'll be safe from mud and rocks?
I'm looking at either a flex-a-lite HD dual circuit cooler (power steering and engine oil), their 20"x5" oil cooler, or just an generic hayden tranny oil cooler, since there are literally millions of them on ebay!
Thoughts?
Old Jun 30, 2010 | 06:19 PM
Danny Lee 97 Disco's Avatar
It seems to me that the place to look at would be right behind the grill, I would also change out that stock plastic grill and do something like some billet bars or a formed piece of sheet with cutouts or louvered.
That would be way cooler than stock.
Old Jun 30, 2010 | 09:04 PM
Put it on the roof, plenty of air flow no matter which way your going.
Old Jun 30, 2010 | 10:47 PM
turbogregtn's Avatar
extra coolers always good, put a colder thermo while ur at it
Old Jul 5, 2010 | 01:48 PM
kingsly's Avatar
Well, I've got the oil cooler. It's a flex-a-lite 20"x5"x3/4".
Now the question is, do I modify the existing oil cooler lines to reach around to the new cooler or blank them off and use a sandwich adaptor on the oil filter?
