Removed steering wheel to center. . now clicking
So having an airbag makes centering the wheel a PITA. disconnect battery, wait 20 min, try to get it centered. Disconnect battery, wait 20 min, try again.
After installing the wheel, I have a clicking sound from the multi function ring. Is it aligned wrong or something. Do I need to reseat something I missed.
Any help here would be . . .helpful.
Thanks,
Thanks,
You pushed your combi switches in too far on the steering column.
There is a locking pin on the clock spring that keeps it from turning when you remove the steering wheel.
If the combi switches are pushed in too far the pin will lock the clock spring and it will click.
Carefully grab the turn signal and wiper stalks, wiggle and pull them toward the steering wheel until the noise goes away.
firstgeer (07-20-2018)
I had to remove the wheel after replacing the steering box because I rotated the steering shaft while the box was out and it was like 90 degrees off, not one or two teeth. There isn't that much adjustment in the drag link to fix a 90 degree error. Since I can't get the universal joint off the steering box now while it is in the car (due to buggered up teeth on the input shaft on the rebuilt steering box, see post on another topic) my only choice was to remove the wheel to get things straight.
i had to remove mine cause the clockspring started to shred producing tiny but long shreds of metal where the wheel meets the column. started to create drag and made steering a *&%#. removed the clockspring and she steers great. no horn or airbag now but she turns nice. i wonder if i should put a new clockspring in.
also, she's definitely not 100% straight. minimal and easily dealable. don't even notice anymore. was told it was a result of the lift.
Thank you so much! This worked to fix the clicking from my steering column. No work had been done on mine, just one day started clicking. I wiggled the signal and wiper back. Now, no more clicking!
