Replacing shocks, coil springs too?
Old Aug 20, 2012 | 02:48 PM
antichrist's Avatar
Yeah, you're right. I was thinking of when I replaced both. Which I need to do on my '95, actually.
Old Aug 20, 2012 | 04:15 PM
fishEH's Avatar
It's all good. I just did a lift on a friend's truck Friday so its all still fresh in my head.
Old Aug 20, 2012 | 08:22 PM
The cheap shocks I used, Gabriel, have a lifetime warranty.
It only takes about a hour to replace all four shocks, so even though they wont last as long as the $400 shocks, who cares?
Your next set it free, and the set after that, and after that, and...
Old Aug 21, 2012 | 08:39 AM
Toyfare's Avatar
If I'm going to replace the front shocks (which are in horrible condition), should I also just bite the bullet and replace the rear shocks?
Old Aug 21, 2012 | 09:08 AM
bcbp's Avatar
^ yes do all four and be done with it. The rears are very easy to replace, the only 'special tool' that would be helpful is a pipe wrench to keep the shock from spinning.
Old Aug 21, 2012 | 09:40 AM
jbunner's Avatar
Didn't have to remove spring on my 95, just have to have the correct tools and patience.
Old Aug 22, 2012 | 07:12 AM
fishEH's Avatar
Yes, replace all four shocks at the same time.
Old Aug 22, 2012 | 03:41 PM
b63215b's Avatar
Fish if we are just doing a 2 inch lift what shock lengths should we be running?
Old Aug 22, 2012 | 04:04 PM
fishEH's Avatar
If you're not going to go crazy with articulation, removing swaybars, cones, running eye to eye shocks, etc., then any of the +2" lift shocks would work. Terra Firma, OME, Bilstein are all pretty good. Pro Comp are cheap and people either love them or hate them. There's a rumor that Ironman are good but I don't know anybody running them. If you get OME be sure to get the ones with the "L" suffix, they're longer. Otherwise the standard OME's are really short and a waste of money in my opinion.
Old Aug 24, 2012 | 05:00 AM
Walko327's Avatar
I would do springs and shocks all at once. If springs are original they are worn and sagging and bumps and cornering will cause squeaks and such. I love my terra firma medium duty kit came with coils and shocks and 2" of height. got whole kit for like 420$. First time to ever touch coil suspension and it took me, buddie and dad 10 hrs to do all suspension pieces though that's total labor time. I busted a rear upper shock mount and had to wait a day and half for pt schram to send me some used ones at a great price but besides that sheared bolt job went easy peasy. Just soak everything in pb blaster day or two before job till u start it.
