roof light wiring
How bout the rear lights? Gonna run them off a switch on the rear pillar
I actually had Lucky8 do the job for me, as well as a ton of other work like a new ARB bumper, VR10000# Winch & LED driving lights, Rear TerraFirma bumper, a Mantec Snorkel, and got all of the bits & pieces I installed over the past year or so working together so the Disco runs like new! They ran all of the switches from an extra switch pod I installed where the ash/coin tray was. They put the Blue Sea power distribution box next to the battery, and the relays for everything in the open space in front of the battery. Will get some pictures posted for you. The only issue they had was they couldn't use the (aesthetically pleasing) rear fog switches I wanted as they kept cutting off, so they just used the cruise control switches instead.
If your roof rails are gone you can use rubber hole plugs and then run wires through the plugs.
If not, I'd run wires up the A pillar, or drill a hole in the roof and install a water proof power connector.
