Rover won't crank and alarm keeps going off
Old Feb 7, 2012 | 05:15 PM
  #21
Chris-bob's Avatar
If you wanted, you could throw a 12v powersport battery(motorcycle, lawnmower) from the cheapest place and it would run fine, you'd just need a jump every time you wanted to start.
Let's start over. Does your LR start currently?
Old Feb 7, 2012 | 05:18 PM
  #22
Interstate is what came in it from the factory.
I have a Duralasat Gold battery, battery brand makes no difference and the guy is giving you a line of crap.
The truck has no way of knowing what battery is in it.
As long as it meets the minimum CCA you can use whatever battery you want.
650CCA is the minimum you can use in your truck.
Keep in mind that most batteries are almost dead when you buy them, they loose charge sitting on the shelf.
If the alarm was already tripped when you unhooked the old battery it will pick up right where it left off with the new battery.
Old Mar 15, 2023 | 03:32 PM
  #23
martez's Avatar
Default New battery keeps dying want start
Originally Posted by Marnold-98-Disco
I locked my Rover and came back to it about 3 hours later and now it won't crank and alarm keeps going off. Wtf?!?
2007 Land Rover Range Rover want start got a new bratty still nothing change the alternator nothing everything keep going off no lights nothing
jordamf
Mar 1, 2018 12:44 PM
Tercan
Jun 20, 2017 08:43 PM
ayzerlazer
Jun 9, 2015 03:36 PM
nelbra
Sep 23, 2009 10:55 AM
chiasurf
Jan 31, 2009 04:28 PM
