RTV seal the crankshaft?
Old Feb 13, 2013 | 01:02 PM
slanginsanjuan's Avatar
Default RTV seal the crankshaft?
Not gonna do the crankshaft seal or the head gaskets for the moment.
Spike, remembering you got a 4 year seal on that. Any procedure for that or just get in there and do it?
Old Feb 13, 2013 | 01:28 PM
EricTyrrell's Avatar
RTV on your shaft does not sound like a good idea.
Old Feb 13, 2013 | 01:34 PM
Hey you like what you like and I like what I like.
Spike says there's a trick. I need some tricks.
Old Feb 13, 2013 | 06:09 PM
ihscouts's Avatar
Even a new seal won't do a thing on a worn pulley. If you have a groove on the crank pulley you'll need to replace the pulley or fix a repair collar to it. Fun either way. Why not replace the seal Slang? It's a cheapo part and at least that is super easy to remove once the pulley's off. I've done it (forced to) so I know it's not hard.
Old Feb 13, 2013 | 06:40 PM
Wood screws can pull it right out. But the finger of RTV coating around the shaft will cure overnight, when cranked it makes a hairline split, and will slow the leak. But it is not a long term fix.
Old Feb 14, 2013 | 06:15 AM
well Spike got three years.
i'm semi retiring the vehicle....i don't want to put any more effort or money into it for the time being. i need to get the D2 road worthy.
Old Feb 14, 2013 | 06:17 AM
it needs a new headgasket...so why stop there?
actually the pulley is squeaking I think so you're probably right about that.
Old Feb 14, 2013 | 08:07 PM
I've been computerless...
RTV on my finger, gooped up all around the seal after I cleaned/dried it off.
I got a good 3? years out of that "repair", it was meant to be a temp fix to slow the oil leak until I could replace the seal.
It worked so well I left well enough alone.
Then it started leaking again in the dead of winter of course, a bottle of White Shepard added to the crank case and then a nice 3.5hr drive and it stopped the leak for another 2 years.
This summer it is getting fixed the correct way.
If your truck is not going to be a daily driver fix it the correct way, its a $2.00 part and a hours work.
If yours is leaking like a sieve and you need to get to work in the morning...go for it.
Old Feb 15, 2013 | 09:42 AM
Ha!.....Yeah honey I'll be out working on the truck. It'll only take me an hour!
Seriously, I need a new headgasket, new oil hoses, crankshaft gasket and probably a pulley, new sump gasket and sump plug and washer. And an oil change.
I'm thinking I can cut the problem by 75% with the sump gasket/plug and park it awhile. Maybe then see why the brake fluid is leaking, stop that and move on to the D2.
Old Feb 15, 2013 | 12:01 PM
re: Yeah honey I'll be out working on the truck. It'll only take me an hour!
To find all your sockets.....
