Rubber fob + seawater....
Old Mar 24, 2013 | 01:56 PM
gorry's Avatar
8th Gear
Default Rubber fob + seawater....
Hi, note to self... Don't swim in the sea with car keys in your pocket ! Now keyfob thingy won't work... Can I fix it ? Or, how much for a new one ? I'm in New Zealand.
Thanks.
Old Mar 24, 2013 | 04:26 PM
Open it up, rise with fresh water, dry it, see what happens.
Otherwise you are going to have to buy a new one, prob more than your truck is worth.
Old Mar 24, 2013 | 07:20 PM
coors's Avatar
Use alcohol not water to clean it out. Then bury the fob's electrics in rice for a few hours. Good luck.
Old Mar 24, 2013 | 08:24 PM
Racer X's Avatar
Denatured Alcohol. Open the fob, remove the battery, and immerse the entire fob in the alcohol for 2 hours. Use a soft tooth brush to remove any salt deposits you see.
Then bury the fob in uncooked rice under a lamp for another 2 hours.
Then cross your fingers, put it all back together, and give it a go.
nh9095
Jan 14, 2019 12:36 AM
jfall
Nov 8, 2012 10:08 PM
missoulanancie
Oct 17, 2006 11:32 AM
gabrielhl
Oct 12, 2006 01:58 AM
duckworthlr
Jul 27, 2005 01:21 PM
