Running stock wires with Bosch +4s?
Wondering if it's still suggested to go with the magna core 8mms with our discos (vie got a 97 discovery se) if I went with Bosch platinum 4s for the spark plugs? I didn't have a choice as they were the only set the local auto Zone had in a full pair. Just wondering as I will likely have ton order them online since nonlocal stores have them, and I want to make certain thats ok before i do.
If i should, does anyone have a suggest site or friend they would suggest? I wouldn't mind hooking up a store owner or affiliate up here with my business after all the help I've gotten.
http://www.apexperformance.net/CartGenie/prod-1156.htm
This is where I ordered from. Cheapest I found around... just choose the 8MM.
You are def gonna want to get those 8mm Magnacores. If you try to run stock wires you are gonna most likely get weak spark, a rough idle, and poor acceleration. Lots of newbs that pop up on here start off by asking why they have above said problems. New wires (8MM) with new plugs clears up most of them.
tcbinaflash
10-15-2009 09:31 PM
OJs DNA
11-12-2008 08:26 PM
