Running super rich, bogging down, new to the community.
Old Sep 18, 2014 | 12:37 PM
mbwoodyard's Avatar
8th Gear
Default Running super rich, bogging down, new to the community.
Hey guys, I've recently purchased a 95 disco 5spd. It was running great for a while and recently started to bog a little between 1k-3k. Also a major lack in power.... I replaced the plugs, wires, dizzy cap, and rotor. I also had a new muffler installed. Now, when the engine is cold, it runs a lot better, but when it gets to temp, the symptoms really show.
It also runs very rich. PIG RICH! Any idea's what could be causing this guys? I have searched and been piddling around the forum, It would be nice to get a for sure answer or someone who has experienced the same issues.
Thanks,
Woody
Old Sep 18, 2014 | 03:35 PM
Shiftonthefly1's Avatar
Mine hasnt run rich but on other trucks I always looked at the typical culprits. TPS was a big one on my Toyota. Ran really rich until I adjusted it correctly.
Another cause may be coolant temp sensor. That tells the computer when to "turn off the choke" so to speak when its warmed up.
Also be sure all oxygen sensors are functioning properly. They can mess with the mixture.
Im sure there is way more Rover specific possibilities. Do you have the RAVE manual?
Old Sep 18, 2014 | 07:03 PM
mbwoodyard's Avatar
8th Gear
I have the Hayne's manual, but it isn't too helpful in my situation.
Also, I am not throwing a CEL.
Old Sep 18, 2014 | 09:32 PM
ihscouts's Avatar
Download the Rave, it's the service manual. You might not be throwing a CEL but have you checked the codes under the passenger seat?
Old Sep 19, 2014 | 12:27 PM
mbwoodyard's Avatar
8th Gear
Well guys, today i was driving and it completely lost power. Car turns on and idles fine, will rev just fine, but when i put it in gear and try and drive, it hardly moves....
SUPER FRUSTRATING.
Old Sep 19, 2014 | 05:42 PM
mbwoodyard's Avatar
8th Gear
update!
I went to pull a part today and grabbed a TPS and MAF. I changed the tps and the truck is totally running better, but now I have a CEL. I'm gonna head to autozone tomorrow and have them scan it for me.
Anyone have a link on how to check the codes under the passenger seat like mentioned above?
Old Sep 19, 2014 | 07:11 PM
ihscouts's Avatar
It's OBDI, you cannot have it "scanned".
Land Rover Troubleshooting: retrieving fault codes
Old Sep 20, 2014 | 10:53 AM
archaeology_student's Avatar
Thumbs up
SUPER FRUSTRATING.
Mine did the same, turns out it was the Idle Air Control Valve needed a good cleaning. Mine would stall coming to a stop while driving... seemed to cough at startup... once I did that, issue went away
Good luck
kcabpilot
Dec 4, 2012 02:27 PM
Brian Barr
Jan 13, 2012 08:29 AM
bcolins
Jun 21, 2011 08:06 AM
elboy0712
Mar 14, 2010 10:00 PM
chrisww2
Jan 24, 2008 05:06 PM
