Safety Devices Roof Rack Question
I saw a pic on google when I was searching this same thing. It was formed fiberglass/plastic with a rubber gasket running the length of the rack sealing the space between that lower bar and the roof. If I recall correctly It was for the factory rack on older models. If I come across the pic I will share.
Evening guys,
Apologies for jacking in, but I have been obsessed with the same issue.
Any luck on that SD fairing? I'm about to spring for a Yakima.
I wonder though - some pics I've seen have the fairing placed over the sloping tubes and touching the roof, and others have it on the topmost tube and touching the sloping tubes, like Baja rack pics...I thought the idea was to cover the open space between roof and rack?
btw, Jwehking - I wrapped bungee cord but on the topmost tube, anyways, they rotted - thinking of using pre-slit rubber like: Thanks guys.
The pipe insulator works great but was so ugly haha. Had to remove it. I had it on the bottom bar so it sealed the gap between the bar and the roof. Result was No wind noise at any speed. At a compromise now, I’m using tv coaxial spiraled on the bottom bar. Will get lights soon and I think that will reduce the noise too.
I took down my 4 Hellas so the whistling past 50mph is driving me nuts.
fisherman1051
08-06-2007 12:51 PM
JohnLRDisco04
04-24-2007 11:24 AM
dinandan
07-04-2006 10:43 AM
dinandan
06-22-2006 07:22 PM
