Seafoam how to?
http://www.landroverclubvi.com/seafo...procedure.html
In our very own tech section, but yes. They seem to be pretty similar
Well because we have a different set-up than the DII, you will need to hook up the tube in a different spot. I did this over the weekend and pulled the little vacuum line from the back side(side closest to the firewall) and put on my clear tubing. I just used a standard tube made for fish aquariums. Just control the flow like the write-up says and you should be fine.
I used to work at a shop as a teenager, and we had a BG device for cleaning the injectors (and intake too):
BG Company
The engine actually ran off the cleaner instead of fuel. We had an 80 series landcruiser come in once that had a dead miss on a cylinder. We ran a can of cleaner through it and it cleaned up a stuck injector and ran perfectly smooth after. I called a couple years ago to price one, and they were only about $200. Assuming that they haven't gone up much over the years, it might be something worth a club or group purchase, if you live in an area with enough people to share it. Heck, we charged around $100 to perform this service, it would pay for itself in just a few uses.
BG Company
