Seriously, why me. Now running hotter.
Old 06-13-2016, 03:44 PM
FLA Rover's Avatar
Default Seriously, why me. Now running hotter.
So I replaced the water pump, installed a 180 deg thermostat down from a 192 deg, get it all buttoned back up filled her with properly mixed anti-freeze and added purple ice. Before if I kept below 70mph she would run at 192.2 now she runs 195.8 and gradually climbs... WTF! I could keep her temp down if I needed to by running the heater, not now...
Old 06-13-2016, 03:49 PM
Charlie_V's Avatar
Geez. Rover tricks.
Almost surely some air somewhere in the cooling system.
Old 06-13-2016, 03:53 PM
Shiftonthefly1's Avatar
Air in the system definitely
Old 06-13-2016, 05:48 PM
xathor's Avatar
There are kits that will create a vacuum on the cooling system allowing you to draw coolant from a container into the cooling system without the possibility of air coming into the engine.
Old 06-13-2016, 06:20 PM
ihscouts's Avatar
Besides air are you sure you routed the serp belt correct?
Old 06-13-2016, 06:29 PM
stillruns's Avatar
What is the difficulty level in installing a 180 degree thermostat?
Old 06-13-2016, 08:17 PM
Gimebakmybulits's Avatar
Could also be a faulty stat. When I swapped mine the Stant Super Stat I purchased was faulty out of the box, tossed in a NAPA stat and no problems so test before installing.
Old 06-13-2016, 08:18 PM
Depends on whether or not you shear one of the bolts off like I did.....
Old 06-14-2016, 12:50 AM
jhmover's Avatar
I'd go with air bubble. I put a new radiator in my son's D1 and it ran fine then it started heating up again. I jacked up the right front and fired it up and the coolant level dropped looking through the top filling port. I put another 1/2 gallon of coolant in it. Been fine ever since.
FLA Rover (06-14-2016)
Old 06-14-2016, 08:00 AM
Toran's Avatar
Might this be helpful in removing air from the system
Stealth Conversions V8 Cooling System Parts - Coolant Sight Glass
Quick Reply: Seriously, why me. Now running hotter.
