She's Cooked. Help!! 😩🤣
Old Sep 3, 2022 | 12:03 AM
Sunburnt_Gecko's Avatar
Originally Posted by JohnZo
That's a bit low. I guess I would try a spoonful of engine oil in each cylinder to get the pressure up. The water likely washed out the oil on the rings. After that I would check that the injectors are actually firing.
So what path do you think the water took to get into the cylinders? Exhaust or Intake?
Yea I'll give that a go.
Definitely the intake
Old Sep 3, 2022 | 08:47 AM
robertf's Avatar
that low compression on all cylinders sounds like a worn out timing chain
was the gas tank underwater too?
Old Sep 4, 2022 | 03:31 AM
Yea great.
The tank went underwater for a second but the filler was well out.
Old Dec 30, 2022 | 06:08 PM
Default Sorted!!!
Thanks for the help guys!!
turned out to be a busted wire between the ignition and the coil. So power was sperattic and then there was just nothing. Replaced that and she ran fine.
Old Dec 30, 2022 | 06:21 PM
Harvlr's Avatar
Thanks for letting us all know the fix.
Loverface
Jun 14, 2015 05:11 AM
Adam78
May 26, 2014 11:34 AM
Skogbergs
Dec 4, 2011 01:42 PM
Snafu / Disco Fries
Apr 8, 2011 10:26 PM
Peter 300
Aug 11, 2010 04:42 PM
