Shock Replacement
Shock Replacement
Been working on getting my 97 Discovery 1 back into shape, slowly since I have limited funds, and still working on getting my knee to work after surgery.
I got replacement shock for the drivers side , shock that is on the truck somehow melted the rubber bushing on the top end (how does that happen??) Anyhow, U can't get the nut to turn and the shaft doesn't want to stay in one place. Tried a wrench on the flats of the shaft, with a wrench on the attaching nut. Wrench on the flats of the shaft just slips. Tried the 'universal vise grip' with the same results. I went to use the old stand by 'fire wrench' and cut the end off , only to find I am out of acetylene.... With limited funds, and no other projects for the torch, I am hesitant to tie up the money for a tank of gas just to use it and have it sit for who knows how long..
Anyone have a clue what a shop would charge to cut out the old shock and install the new one (one side only) I know they don't like it when you bring in the parts, but they already told me they couldn't get a replacement shock for a few days when I asked a while ago. Just want to be sure I don't get taken to the cleaners on labor. Can't see that it would take too long to do..
Talked to the guys at NTB and they were kind enough to give me a quote to install one shock on my truck, I have the part, .... $160!!!!! I guess I am in the wrong business! seems a bit steep for cutting off a shock and putting another one in it's place....
For that price, I will crawl under and do it myself, messed up knee and all!!
You should be able to get it though. Try a propane torch on the nylock on the bottom. Melt out the nylon and it will come off easier. Use a pipe wrench to hold the shock from spinning.
Or maybe try to squeeze a sawzall blade in there and cut through the top rubber bushing on the lower mount and cut right through the stud.
You can do it! You can always buy new tools to DIY and still come out ahead of paying a shop.
I bit the bullet and refilled my tanks. turns out that was the cheapest way to go. I checked with 2 other shops (both independent shops) and was quoted a higher price by both. Top price was $265. and that was just labor!! I guess we know why I don't have any of my cars worked on here in town.
I noticed they ran the ABS sensor wires right next to the shock bottom nut. Think it is flame proof?? (just kidding) I figure once I get the top cover lose, (3 bolts) it won't take long to (fire) wrench the shock out. Refill on the tanks was just under $100... I still save at least $60, plus I got fuel for the next project that needs a little heat...
