Sluggish 1998 Disco
When I first got mine, it seemed pretty weak compared to what I was used to with other vehicles.
I worked my way thru new plugs & 8mm wires, new air filter, replaced the vacumn hoses (the EGR hoses), oil change, new fluids totally (tranny, t/c, diff's) and all the typical goodies. I only use 93 octane (usually Shell or Sunoco).
I also replaced the fuel pump assembly due to a cracked top, new fuel lines due to corroded old ones, new fuel filter as well.
With all that it got better and better with each change. Now it is actually "peppy", and even responsive especially after the EGR hoses and a new LR paper air filter.
What EGR are you talking about..we dont have EGR
I run my tires at 35psi all the way around.
Sorry I forgot to put that in the last post. It's the Hayden 2626 from Checker. It was only $54 with the bolts so I wont be made if I need to buy a different one.
