Sluggish 1998 Disco
Old Jan 13, 2011 | 12:16 AM
thehun's Avatar
i only get 13-14mpg...i think your engine runs just fine
thehun's Avatar
Originally Posted by Danny Lee 97 Disco
When I first got mine, it seemed pretty weak compared to what I was used to with other vehicles.
I worked my way thru new plugs & 8mm wires, new air filter, replaced the vacumn hoses (the EGR hoses), oil change, new fluids totally (tranny, t/c, diff's) and all the typical goodies. I only use 93 octane (usually Shell or Sunoco).
I also replaced the fuel pump assembly due to a cracked top, new fuel lines due to corroded old ones, new fuel filter as well.
With all that it got better and better with each change. Now it is actually "peppy", and even responsive especially after the EGR hoses and a new LR paper air filter.
What EGR are you talking about..we dont have EGR
Old Jan 13, 2011 | 10:46 AM
Danny Lee 97 Disco's Avatar
The ones from the top of the vavle covers to the intake, whatever they are called.
Edit: PCV hoses, I guess.
Old Jan 13, 2011 | 05:01 PM
Originally Posted by utrover
Thank you for your input. As for your questions, I've only had it about a month. I have had a 96 and a 97 Discovery with more miles and more power than this one. That being said I do know there has to be something that can be done, I just need some guidance to find it.
I would start with a tune up and a air filter as well as tire pressure.
I run my tires at 35psi all the way around.
Old Jan 13, 2011 | 05:41 PM
thehun's Avatar
Yeah I was like...what?
Old Jan 15, 2011 | 03:56 PM
utrover's Avatar
Okay I just drove my brother-in-laws 99 D1 with around the same miles and there is for sure something wrong with mine. His has a lot more power and its quieter. I replaced the fan clutch when I bought it but it still is running all the time. This may be were my power loss is coming from.
Old Jan 15, 2011 | 05:19 PM
What fan clutch did you use?
Where did you get it from?
I originally replaced mine with a OEM one but they sent me a heavy duty fan clutch and my truck drank fuel like it was free.
I returned it and used the Chevy fan clutch from the tech section and no problems since.
Old Jan 15, 2011 | 07:02 PM
utrover's Avatar
Sorry I forgot to put that in the last post. It's the Hayden 2626 from Checker. It was only $54 with the bolts so I wont be made if I need to buy a different one.
Old Jan 15, 2011 | 07:50 PM
I have no idea what that part number means.
Did you buy a Land Rover fan clutch? (I mean a fan clutch for a Land Rover?)
Old Jan 15, 2011 | 11:00 PM
utrover's Avatar
It was for a chevy van i think.
