Smoking Disco
Old Nov 29, 2011 | 09:38 PM
Jake1996D1's Avatar
Originally Posted by Spike555
Personally I think things just need some miles to work out the "kinks".
When you sucked in the water you exploded all of the carbon off of the exhaust valves and piston tops, any that got into the cats will be burnt up and probably smoke while it does so.
O2's are reading good, no coolant loss, no oil loss?
I would wait and see, drive it normal for a week, checking the fluids often.
MAF is still plugged in?
Yea new MAF - oil was on the low side of the stick so I'll top it and drive it. Dont remember how much was in it before since I changed oil a couple times.
Old Nov 30, 2011 | 04:22 PM
Jake1996D1's Avatar
Drove it today for a while. Got codes 1314 and 1316 - still smoking. Pulled plug 8 was fouled. I'm thinking it's fuel related. Hard to tell at this point I'm at my wits end.
Old Nov 30, 2011 | 08:52 PM
Maybe your cam sensor got soaked and is now toast?
The cam sensor controls the injector timing.
Old Nov 30, 2011 | 08:59 PM
EricTyrrell's Avatar
I know how you feel.
Old Nov 30, 2011 | 10:14 PM
Jake1996D1's Avatar
Yea thought of that and ckps.. Doesnt explain bank dependency though.. Will try it after ECU
Old Nov 30, 2011 | 10:15 PM
Jake1996D1's Avatar
Thank you for allowing me to cry on you shoulder lol
Old Dec 1, 2011 | 05:03 PM
Jake1996D1's Avatar
drove it today here's a picture of the smoke for color reference.. White with blue hue
Uploaded with ImageShack.us
Old Dec 1, 2011 | 08:16 PM
I know exactly what that is, it is getting to much raw fuel dumped into the cats, that is what happens when the cats burn the excess fuel, it smokes like that, and that color.
My wifes car does it at idle, if it idles to long it smokes exactly like that, it has a bad fuel injector and it is dumping to much fuel into cylinder #3, I also get a misfire code on that cylinder.
On her car low quality of fuel makes it smoke more, high quality it smokes less.
I am not looking forward to replacing the injectors on that thing.
Old Dec 1, 2011 | 08:25 PM
Jake1996D1's Avatar
Interesting., kinda what I figured now I just have to figure out why it's happening on one bank only. Gonna put some fresh plugs in and run them. See how they turn out. I'm not getting any cylinder codes so I can't pin point it. Smoking like he'll though
Old Dec 1, 2011 | 08:32 PM
Switch fuel brands and see what happens.
