SOLUTION: lug wrench bending
Oops.. didn't mean to post this under discover I.. it belongs under general tech help.
Is your lug wrench bending under your brute strength trying to break the lugs? Mine was. Well, I found a solution.
If you have a portable propane torch and sand paper, first sand off the paint at the bend (roughly 2 inches), then try to get the bend back close to the original angle. Next, with the wrench laying on concrete or granite surface plate and away from flammables, heat the bend for no more than 5 minutes. Let stand until fully cooled down. This process will harden the steel to about 45 to 50 rc.
Viola! Worked like a charm for me
When I first tried to get the lug nuts off my Disco I used a 5 or 6 foot pipe as a cheater bar and had the whole truck practically bouncing off the ground. Very comical, but I eventually succeeded. Now, I make sure no one but me torques them nuts - if at all possible.
im imagining many of these issues are due to overtorquing in the first place...
Make sure the tire shop is using a torque wrench and not a impact wrench when doing tires for you.
