Source For Door Moisture Barrier
Old Jan 18, 2011 | 11:50 AM
LeakyDisco's Avatar
Default Source For Door Moisture Barrier
Hi,
After pulling my driver/passenger door panels off a couple times for various repairs, the brittle plastic moisture barriers are mostly shredded.
Has anyone managed to find a source for a similar material that would work to replace the original stuff?
Thanks!
- Chris
Old Jan 18, 2011 | 01:53 PM
Cosmic88's Avatar
Default good old home depot...
painters plastic drop cloth (polyethelyene sheeting) ....go with the thick stuff at about 8 or 10 mil. It comes is large rolls for commercial applications of folded sheets for diy at hope jobs.
OR
try this out???? I have never used it in this application so I have no idea how well it would stick... http://www.homedepot.com/Paint-Drop-...atalogId=10053
Old Jan 18, 2011 | 02:02 PM
losinov's Avatar
I'm just going to go to home depot and walk around/ask someone to show me a material similar to the one the barrier is made out of. Then just cut to fit and transfer the little speaker cutout.
What do you guys think the black sealant is? At least in my car it is black RTV lookin stuff
Old Jan 18, 2011 | 10:34 PM
LeakyDisco's Avatar
OR
Thanks.
I'll go check out the local Pro Build and/or Home Depot this weekend and see if they have something that closely matches the thickness of the original.
Old Jan 18, 2011 | 10:36 PM
LeakyDisco's Avatar
It does appear to be an RTV adhesive.
Old Jan 19, 2011 | 01:47 PM
Chris-bob's Avatar
What about http://www.hobbytown.com/Shop/coveri...y-film-white-6 ?
Old Mar 13, 2025 | 07:03 PM
LordReaper98D's Avatar
7th Gear
it isn't. It is 3M Butyl Paste. Find in 5 oz tubes at Napa, and other fine auto parts stores. Black and green box black and green tube with customary red 3M branding. Now you know.
3M Black Super Weatherstrip and Gasket Adhesive, 08008, 5 fl oz, 1 Per Pack
Old Mar 13, 2025 | 07:08 PM
7th Gear
PS, you can also order it in butyl strips kind of like strips of tack gum stuck to a large piece of waxed paper. Peel and stick, then stick vapor barrier to strips.
Old Mar 13, 2025 | 11:50 PM
Icannap1's Avatar
Home Depot
Gibraltar Building Products
50 ft. Butyl Sealant Tape Roof Accessory in Gray
Old Mar 14, 2025 | 07:47 PM
7th Gear
Originally Posted by Chris-bob
what about what??? Your link takes us to nowhere. Sorry.
i did answer the tread question about the black stuff empirically though. See my replys.
