Starting issues
Old Jul 26, 2010 | 09:06 AM
Law Dog's Avatar
Default Starting issues
I have a 98 Disco. The engine turns over but wont start. I can start it using carb cleaner. (works better than starter spray). Once the engine starts it will run pretty good. After running it, I can stop it and even after two hours it will start ok. After a day though, it wont start. Can anyone help????
Old Jul 26, 2010 | 09:19 AM
Have you replaced the fuel filter?
Have you checked the fuel pressure at the fuel rail when it wont start?
Old Jul 26, 2010 | 09:28 AM
Law Dog's Avatar
Not much of a mech here, but as often as this thing breaks down, I should be one shortly. I haven't done anything yet. Fuel filter is next and cheapest fix. I spoke to a mech who said that it sounds like a fuel return problem (fuel is returning to the tank instead of staying in the lines, hence the vehicle not getting fuel on startup. I don't want to deal with a fuel pump if I don't have to.
Old Jul 26, 2010 | 11:04 AM
XCELLER8's Avatar
2X on the fuel filter & maybe the pump.......you need a fuel pressure gauge to make a better diagnosis
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
jbremser
Dec 26, 2007 01:50 PM
jrsherfy
Aug 24, 2007 05:47 PM
clacaria
Mar 18, 2007 03:26 PM
mbroker
Freelander
Nov 24, 2006 10:26 PM
