Steering noise
Old 03-23-2014 | 03:42 PM
tentoesjoe's Avatar
Default Steering noise
So today I noticed a chirp when driving. After getting home i investigated a little and found it makes a noise when I turn the wheel either left or right. I checked the power steering fluid and it was full and there are no leaks coming from the steering box. Anybody had this issue?
Old 03-23-2014 | 05:02 PM
tentoesjoe's Avatar
After I restarted it up I c ould hear the p/s pump wind up and sound like it was gonna fly away. I think thats the problem, can anybody back me up on that before I spend the cash and also is AB the best place to get a replacement. I have seen nothing but bad posts about a reman one.
Old 03-24-2014 | 08:45 AM
wrongway1's Avatar
Sounds like the bearings are getting a bit tired. Mine sounded like an old fax machine Dave @ AB is a good contact.
Old 03-24-2014 | 01:51 PM
Capital202's Avatar
So I am having some similar issues. I just got home from Afghanistan and went back and ripped the cover off my favorite off-road toy only to find the appearance of a puddle under the engine bay and the steering fluid was empty. After reading through some forums here I refilled the system with some Dex III and PS leak seal, changed the oil, and fired it up. Rear bags inflated normally and I let it run for a little burning the old fuel and replacing it with some fresh. After awhile I am I still hearing a 'whiring' sound at stand-still and more so when I turn the wheel. Is this because of it's time spent without any lube (we all know how no lube can affect the outcome of your night ;-) ) or is my PAS Pump or Steering Box done?
Any help would be great. Not about to bring her in to the shop now, short of being ****ed with a cracked engine block, I can handle this repair on my own I am sure.
Thanks in advance,
ATL
Old 03-24-2014 | 02:21 PM
slskier88's Avatar
What does the steering feel like when you're driving and try turning?
Old 03-24-2014 | 05:44 PM
tentoesjoe's Avatar
The steering feels solid and it turns like it always does. The power steering is working its just the noise. I did drain the ps fluid and put in a bottle of the Lucas stop leak then I bleed the system and the sound has gotten a bit quieter but I got a replacement pump coming from Abran on the cheap just in case it decides to go completely.
david4ducati
03-01-2015 07:59 PM
30more
05-28-2012 05:01 PM
Robbo
06-15-2005 05:03 AM
adrianwood
Freelander
06-13-2005 08:53 PM
Quick Reply: Steering noise
