Stock Ride Height
Tonight, just out of curiosity and because I found where I last laid my measuring tape, I made a few measurements. They are listed below.
Front Wheel Well Center 33.5 inches
The top of the SE 30.5
Top of the Hood 45
Rear Wheel Well Center 35
Top of Stock rear Bumper 30
Top Rear Corner 80
That is with a 2 inch lift on rear, old rear springs moved to front, on stock rims with 235 70 Bridgestone Dueler ATP's all around with about 50 % tread left.
Is that the kind of info you were after? Mine sits noticably higher than it did when I first bought it with the original setup.
Top of the Hood 45
Top Rear Corner 80
ride height
The trouble with using the info on the sun-visor is that is clearance height ...so you know if you can get under a bridge or something. That height will change with tyres and tyre wear.
The spring and lift measurement is best taken from the centre of the axle to the centre of the guard arch.
The std distance is reported to be 470mm . 2" lifters should give you about 500-510.
