stock suspension 245 75 16?
Old Apr 3, 2011 | 09:40 PM
cationmoted's Avatar
Question stock suspension 245 75 16?
i am about to purchase the treadwright guard dogs 245 75 16. Could i mount them before lifting the disco? would they rub the fenders while driving on flat ground?
thanks
Old Apr 3, 2011 | 09:54 PM
jafir's Avatar
here is a good list I found when I had a D1:
Disco Tire Fitting Guide
Old Apr 3, 2011 | 10:07 PM
thanks, but i have seen a thread on here somewhere about temporarily running 245 75 stock
Old Apr 3, 2011 | 10:13 PM
jafir's Avatar
You might get away with it, but trimming the rear fender is free if you have to. Here is a where someone did it, and they had a 2" lift already.... still rubbed.
https://landroverforums.com/forum/di...mel-cut-39163/
Old Apr 3, 2011 | 10:36 PM
tweakrover's Avatar
you are fine putting them on before a lift, thats exactly what i did. you won't run into problems til you start making things flex. just adjust your bump stops
Old Apr 3, 2011 | 10:38 PM
thank you
Old Apr 3, 2011 | 10:43 PM
awesome appreciate your help
Old Apr 4, 2011 | 06:25 AM
jdracersc's Avatar
No problems at all. My 95 Disco is stock and I'm running 245 BFG M/T's. And barely rub @ flex. Will have to adjust steering stops though.
Old Apr 4, 2011 | 05:43 PM
pimnmike's Avatar
I have 245/75 I haven't gone off road, but daily commuting. You should be fine. I have no problems.
Old Apr 5, 2011 | 08:55 PM
CUpgt's Avatar
Im running 255/70s on stock suspension. I can fully flex without scrubbing after a camel cut.
