This is a STRANGE ONE - I think ??
Old May 8, 2025 | 09:46 PM
disco96sd's Avatar
Default This is a STRANGE ONE - I think ??
All of a sudden my key won't turn the drivers door lock to activate the central locking system ( when you turn it left it is hard to turn and will only turn part way left and won't activate the lock and alarm system )and also my (I left on the lights beep beep beep warning) is not working - also noticed my left the key in ignition reminder beep is also not working
all lights work - the doors will all central lock if you are inside the vehicle and my alarm light is normal on the radio
I checked all the fuses inside and in engine compartment - all is well
ANY THOUGHTS ?? HEAD STUMPER . . .
Old May 9, 2025 | 08:28 AM
JohnZo's Avatar
My driver door keys turn harder than I like. Probably lubrication would help (would need door panel removed), but I rarely lock up so I don't notice much.
The ignition switch mechanism has a little lever and microswitch for key-in sensing. That lever can wear or need lubrication, or the key can get worn.
Lights-on warning depends on the door switch (little black plunger on the pillar), which connects to ground when the door is open. Does your overhead light turn on when the door opens? The wire broke on mine, so needed fixing, forgot if I replaced the door switch or not, but new are easy to get.
It sounds like you have an old Land Rover. Keep calm and Rover on.
Old May 9, 2025 | 09:34 AM
disco96sd's Avatar
the fact that it all happened together means one thing must be causing the cascade - light does come on when door is open - things pretty well lubricated - something odd that they all happened at once
Old May 9, 2025 | 04:53 PM
JohnZo's Avatar
Maybe something wrong with the chime/beeper? The beeper pertains to key and lights warnings, not central locking. Might require electrical troubleshooting or tracing circuits to find the common denominator.
Driver's door key mechanism has several linkages. Maybe one is binding up or bent and not allowing enough travel to activate the locks. Not a huge task to remove the door panel to take a look, clean, lubricate, but not a lot of room in there.
Old May 9, 2025 | 10:08 PM
disco96sd's Avatar
JohnZo was a hundred % correct
All the issue were correct
The cascade was the weather
1) it caused an issue with the door switch - that caused an issue with lights on and key in ignition chimes - after a blast of electrical cleaner good as new
2) It caused an issue with the door lock - after lubricating good as new
All is well - lesson learned - a weather event caused it - go figure
krustacean
Mar 20, 2022 05:34 PM
mzcharj
Oct 27, 2014 02:23 PM
earlyrover
Sep 8, 2014 07:44 AM
danvlarsen
Mar 17, 2011 12:00 PM
johnnybob06
Aug 28, 2007 10:38 AM
