stumped
Hello again, I've been having a problem with my 95 disco stalling out, back firing, idling slow, i can get up to speed with ease its just stopping at a light or stop sing...
I've already replaced the vacuum hose, cleaned the Mass Air Flow, cleaned the Idle Air Control Valve, put in dry gas, fuel filter replaced.... if yall have any ideas on how to fix it please let me know.
Thanks Collin
Thanks Collin
I have a '96 with OBDII, but I believe the '95 has OBD codes also, but you have to count blinks on a gadget under one of the seats. Have you checked the codes ? It does sound like a vacuum leak somewhere. That would make it backfire and idle poorly.
Maybe. It doesn't hurt to look under the seat and check. I think there is no counting... I think it's one or two 7 segment LEDs and just shows you a number.
At idle? It should be like 17~22 inHg at idle (or at least my 95 is and it runs great). A bad vacuum leak would most certainly cause poor performance.
