Sway bar disconnects or just no sway bars???
I want to make some disconnects for my sway bars but I don't know what to do with the sway bars after I disconnect them. It seems like they would just hang there and hit the ground or do they rest on some thing. And since it's easier to remove the sway bars should I do that. What will be the consequences whine I do this.
on
First, is your suspension stock, if so you would be wise to wait till you throw a lift on it otherwise you will have a stability issues cause of the weak springs.
As for the disconnects, when disconnected, hold the sway bars up with a bungy cord and don't drive on the road with it till you get real used to how it handles cause you can loose control and crash.
Older RRC (and maybe even some older discos before they sold them in North America) didn't even come with sway bars. I'll bet you'll be fine with HD springs and no sways.
Have you ever driven one on stockers with no sways? It's moderately terrifying.
I drove my buddy's 1990 rrc with ome shocks and springs, and it wasn't scary. I figured since the guy I replied to was just now installing the HD shocks and springs that they don't have any miles. I'll bet it handles just fine, and he'll get an extra inch or two of flex.
I'd still rather have sways on when I'm on the street regardless.
I can't recall a time I've ever needed that on the street. And that's why disconnects work just fine for me.
I suppose if it's exclusively a trail toy this doesn't matter, but I use mine for sloppy weather duty as well. Just offering an opinion here. It's up to whoever is driving it to make that choice. Fortunately, it's easy enough to disconnect them and drive around for a bit to figure out if that's going to work for you before either outright removing them or buying quick disconnects.
Well I drove it before he got the lift too... and it had 170k on it. It drove like crap for the first little bit he owned it because the front shock towers were completely rusted out and busted off at the base.
But that isn't relevant to the post I originally made... which was that I thought someone that was installing HD suspension on a D1 would be just fine without anti-sway bars.
