Sway Bushings... What Else?
I ordered a couple of packages of One Shot Grease from British Atlantic on Tuesday and a few other do-dads since I was "paying for shipping" anyway...
On Wednesday (yesterday) I was under the Disco greasing the zerks when I realized that one of my anti-sway bar bushings are toast (the ones attached to the frame; not the end link). I figured that this had to be the reason why my disco dips into left hand turns, but stays steady on right hand turns....
I am upgrading to an OME HD suspension in the spring...
I want to replace this bushing, but since they cost $6 and shipping is $10, I figure I should replace a few "may as wells" while I am down there as well as pre order parts for my pending suspension install.
What else should I buy?
With 160k on it it's very likely past due to have them all replaced, plus the motor and gearbox mounts. I'd do the A-arm ball joint at the same time since you have to disconnect everything to get it out.
Reports on the poly bushes are are really mixed (early failures and allowing more rapid component rusting). Sticking with rubber is always a safe bet.
I have blue Polybush brand on my 95 disco and rubber on the 97. Only time will tell if the Polybush was a smart choice.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
![Name: utf-8BSU1BRzAzODIuanBn.jpg
Size: 63.5 KB](https://landroverforums.com/forum/attachments/discovery-i-39/44339d1501381471-sway-bushings-what-else-utf-8bsu1brzazodiuanbn.jpg)
I know the sways didnt come in my blue polybush kit if that helps, if I remember right the full kit had radius arm bush frame an axle ends, trailing arm bush's frame an axle ends, panhard bush's, and there was something else in the kit but I forget. I'll see if I still have the packing slip when I get home. I havent had problems out of my blue polys at all they seem to be holding up well.
