Sweet smell from exhaust! ohnoessss
Old Mar 2, 2011 | 10:42 AM
  #51
Spot's Avatar
I think with your experience level, you should probably leave it alone. I don't mean this to sound rude, I'm also a newbie when it comes to engines. But i do know, that when I start 'tinkering' with things, sometimes it ends up worse than it originally was. It would be terrible to get some of the aluminum shavings down inside the cylinder.
Besides, when you get your engine put back together it's going to run 10-fold better than it did. You've refreshed the heads(valvework etc...) so compression should be spot on.
Did you replace the timing chain while you were at it?
Old Mar 2, 2011 | 01:41 PM
  #52
Danny Lee 97 Disco's Avatar
First off, I would never take a dremel to that port, I think you are inviting disaster to the party if you do.
Also, I noticed a few of your exhaust ports were terribly nasty with carbon build-up. I am no expert, but I would think that maybe that could/should be cleaned up while you have it open.
I appreciate the pictures, that is the first ones I have seen with the heads removed.
In the one with the valley pan gasket, looked like quite a few leaks there?
Old Mar 2, 2011 | 05:30 PM
  #53
losinov's Avatar
Yeah I agree with you Spot, might be better to leave things alone I was just getting people's opinions on porting. And you are right about a big improvement just from getting everything cleaned out and sealed up correctly. Compression will improve from the valve seats but I guess the piston rings are the most important when talking about compression. Not changing those out.
@Danny Yeah the heads are getting the treatment and will be beautifulllllll when they're back. I'll post pics when I get them back though.
Old Mar 5, 2011 | 09:02 PM
  #54
losinov's Avatar
Default Help identifying gaskets and rings
I received the package from Will a few weeks ago and I went through everything in the bag of gaskets today to make sure I knew where everything will go tomorrow when we put the heads on. I am having difficulty with the items below. If you guys could lend a hand and identify what goes where i'd really appreciate it!
1)
2)
3)
4)
5)Notice the round edges
6)These 4 are all different, the one on the bottom is actually a spring
7)
8)
9)
10)Not sure if this ring below was included in the package, it may have fallen in the box while I was working around the truck, look familiar?
Old Mar 6, 2011 | 11:06 AM
  #55
It is great that you are going thru it like you are. I believe it is imperative to have that level of understanding before you dive in to such a job. I myself have never torn into one to that detail yet. One piece of advice though is to have a digital camera on hand, take pics at every stage of disassembly to help you document orientation and such as you go. These can be a valuable reference later upon reassembly if questions do arise.
You make try looking at some of the webpages if the RAVE is not detailed enough. I have not really looked at it to see. I am sure some of the more seasoned vets on here cn help you with your questions as well. Good Luck.
Old Mar 6, 2011 | 11:19 AM
  #56
Spencerfitch's Avatar
My guess is 9 is throttle body heater and the 2 is oil or trans crush gasket. Those are the exact parts I still have as I couldn't figure them out
Old Mar 7, 2011 | 01:43 PM
  #57
losinov's Avatar
I gave Will a call and he let me know that I would not be using all the parts as the kit he sends is made to include parts for many of the Land Rover models. I will just inspect and replace as I go. Ordered the water pump gasket today, magnecore 7mm wires, rotor and cap. Now to figure out how to mark the distributor, wire sequence, and how to pull out the rotor without pulling everything else out... O_O
Old Mar 7, 2011 | 02:33 PM
  #58
For the distributor marking you can scribe a line or make punch marks. These are permanaent and won't wipe off.
Also take pics of everything as you go for reference if needed later to put it back together...
Old Mar 7, 2011 | 04:25 PM
  #59
losinov's Avatar
Default Updated Pics
Pictures of clean EVERYTHING! Yay.
Clean intake!
Clean heads!
New Valve seals!
Top view
Beautiful
Just thought you guys would like to see these!
Write up soon to followwwwwwwwwwwwwww.
Old Mar 9, 2011 | 08:35 PM
  #60
Hey that does look great. Glad to see your success. Keep up the good work.
