Switching to synthetic gear oil- question
Old Nov 27, 2011 | 11:41 AM
sclarkie's Avatar
Default Switching to synthetic gear oil- question
Going to switch to synthetic, probably Royal Purple 75w140, in my front and rear differentials. Any problem with draining the old and filling up w/ the new, or do I need to clean it out somehow?
Old Nov 27, 2011 | 11:45 AM
Banzai Jimmy's Avatar
Nope, no problems.
Old Nov 27, 2011 | 12:15 PM
No problems until you need to drain out the $150 worth of gear lube you put in because you went wading or there is a seal you need to replace.
Old Nov 27, 2011 | 01:06 PM
Danny Lee 97 Disco's Avatar
I used Mobil One75/140 in my T/C, it was pretty cheap. Still got the 75w90 Valvoline dinolube in the diff's for now. The Mobil One quieted the T/C down nicely. Diff's doing fine on the lower viscosity.
Old Nov 27, 2011 | 03:41 PM
sclarkie's Avatar
$150? Hadn't priced it yet, just researching on the web. Time to shop around.
Old Nov 27, 2011 | 04:00 PM
$20 per quart, you need 7qts to do both diffs and the t-case.
Royal Purple/1 qt. 75W-90 synthetic Max-Gear oil (01300) | Gear Oil | AutoZone.com
starrock
May 18, 2010 11:25 AM
hilltoppersx
Feb 27, 2010 09:30 PM
muddybuddy
Jun 4, 2009 08:50 AM
herblatham
May 1, 2008 05:57 PM
GCS1
Aug 9, 2007 07:26 AM
