Swivel ball/steering help!
Old Mar 5, 2024 | 01:22 PM
whiskeynipple0088's Avatar
forgive me if mentioned - replaced the steering damper bushings? ......and tight (should reduce to about 1/4" thick when tight).
Old Mar 5, 2024 | 01:25 PM
Trashpanda's Avatar
the damper is brand new, but no, the bushings are not squished down that much. Ill give that a try when it stops raining, thanks
Old Mar 5, 2024 | 11:14 PM
JohnZo's Avatar
Basically, tightening everything up will allow higher frequency (higher speed) wobbles. We haven't mentioned alignment, tire condition and inflation. Tell us about your tires.
Old Mar 5, 2024 | 11:19 PM
Trashpanda's Avatar
brand new factory size tires, brand new alignment, inflated to spec
Old Mar 6, 2024 | 11:56 AM
hrhoward's Avatar
I had one that would wobble pretty bad. Did about five figure eights, lock to lock, in my yard and that seemed to cure the majority of the wobble. Had to be air in the system somewhere as it was sitting up for three years and leaked out. All of it went away after replacing rod ends and such.
Old Mar 6, 2024 | 12:17 PM
Trashpanda's Avatar
Something I noticed today, there's a rotational click in the front left. I plan on rebuilding that hub come summer
Old Mar 12, 2024 | 05:08 PM
Trashpanda's Avatar
this fixed about 95% of the problem. I think with new radius arm bushings and suspension itll be just fine
RoverLife_
Range Rover Classic (1st Gen)
Nov 13, 2018 10:12 AM
gunsanroses91
Apr 7, 2017 12:11 PM
MiamiC70
Jul 26, 2011 09:38 AM
texmanmoore
Apr 29, 2008 01:23 PM
moneypit37
17
Jul 31, 2006 03:03 AM
