Swivel balls scored? Need seals?
Old Aug 15, 2010 | 08:13 PM
greg409's Avatar
Default Swivel ***** scored? Need seals?
I excersized tremendous restraint when thinking of a title. (you know who you are)
Anyway, a couple of years ago, I read on the brits forum about repairing gouges in my *****, as well as on vehicle replacement of leaking rubber
seals.
They rcommended hacksawing the new seal to split it after removing the spring inside.
That would effectively remove metal, so I:
removed the spring from the new seal, then find the split where it's screwed together (magnifying glass) unscrew it.
I cut the new seal with a GOOD pair of aviator tin snips (thru' rubber & steel) in one spot.
Now to the injured ball - (cut off old seal and holder removed but left dangling) I brakecleaned the crap out of the surface, then mixed up some 24hr jb weld.
I spead jb into gouges with a stiff but flexible piece of plastic.
Keep it pretty, but put plenty on it.
Go away and come back tomorrow.
I then used a small file to rough contour it, followed with some 600grit in my palm. (yes, my hand)
When it looked pretty, i took a chunk of the old seal and check shape.
I then contorted new seal into place (no kinking allowed), wrapped spring around and re-wound it back, then installed it onto new seal.
I put rtv around cut in seal (now at top) and re-installed.
filled ball with one shot (ebay $15/two tubes)
There you go, 10k later, still good.
luck,greg
Old Aug 15, 2010 | 09:30 PM
tweakrover's Avatar
So you are saying your scratched ***** were leaking so you replaced your busted rubber by cutting it off, you cleaned then rubbed jb weld on you *****, then sanded your ***** smooth then put a new rubber on by cutting it and sealing it at the top.
Old Aug 15, 2010 | 09:57 PM
Danny Lee 97 Disco's Avatar
And you are just now telling us?
Old Aug 15, 2010 | 10:06 PM
Why are we talking about your *****?
Old Aug 15, 2010 | 10:41 PM
tweakrover's Avatar
He's been living with the shame for 10,000 miles and he can't bear it anymore.
Old Aug 16, 2010 | 01:28 AM
Spencerfitch's Avatar
gouges in my *****,
I think he meant gout in his *****
Hope its not too late
Umm dude there not screwed together. And sorry you need a magnifying gass.
Now to the injured ball left dangling
Man that brake cleaner can BURN.
woah woah woah, stop right there
They say when you think you used too much thats almost enough
Are you into bdsm?
(no kinky allowed),
Too late for that
Old Aug 16, 2010 | 03:08 AM
antichrist's Avatar
Yup, it works. A couple of people on the LRO mailing list repaired theirs with blue epoxy. 14 or so years later and it's still fine.
Old Aug 16, 2010 | 09:34 AM
What causes the pitting on the swivel *****?
Age?
Abuse?
I dont know so I ask.
Old Aug 16, 2010 | 01:07 PM
kenk's Avatar
I've wondered that too. When I rebuilt my swivel *****, I had a couple minor scores/pitts that I filled with standard 2 part epoxy resin, then sanded smooth.
The only part physically touching the swivels is the rubber oil seal. So I'm guessing either corrosion and/or debri getting caught in the rubber seal.
Old Aug 16, 2010 | 09:09 PM
greg409's Avatar
You people are too predicktable - funny tho'
Some times mud, rocks get under the rubber seal, causing irritation, increasing to scratching, surface damage.
Imagine having a piece of gravel held tightly to a ball, pretty soon it may start leaking.
Ok, that's enough for me
Kenk, you're 100% correct, I was surprised the chrome hadn't started to delaminate.
Common wisdom says do NOT use the gaitor covers unless you remove regularly to clean underneath PITA
luck,greg
