swivel pin housing oil?
Old Aug 15, 2010 | 10:31 AM
herblatham's Avatar
Default swivel pin housing oil?
I've been going through and replacing all my fluids and oils this morning and i'm having trouble trying to locate a level plug and drain plug for the "swivel pin housing" I see where the fill plug is and have taken that off, but the picture in the rave manual and what i'm looking at behind the tire don't seem to match? should i just fill it until it seeps out of the fill plug? or would that be too much? thanks
98 discovery
147000
Old Aug 15, 2010 | 11:55 AM
greg409's Avatar
I believe sometime in '97 (like mine) they started using "one shot" grease, it almost pours, but not quite.
With that, they eliminated the drain plug.
You can still fill with gearlube, tho" some people use 140w since it doesn't leak out as fast
I R&R'd ball seal on driver's side as ball was scored badly (jb weld fix), filled with one shot, the pass side has 140 in it (minor leakage), no probs for 2yrs.
luck,greg
Old Aug 15, 2010 | 12:00 PM
jbriggs's Avatar
98 discovery
147000
Its there, but its pretty small. If you fill it all the way to the fill plug it will be over-full. Might lead to bigger problems. Pull the wheel off and it is easier to get to. I used 85-140 in mine.
Old Aug 15, 2010 | 02:57 PM
herblatham's Avatar
Would I be fine using 80-90?
Old Aug 15, 2010 | 04:56 PM
No, 89-90 will be to thin.
Go to your lawn mower shop and buy "00" grease.
Basically the swivel lube is a mixture of grease and gear lube, thick enough to not leak but viscous enough to cover everything easily.
Old Aug 15, 2010 | 06:22 PM
tweakrover's Avatar
the level plug is on the front side of the wheels, right in the middle under the big bolt like the pic shows
Old Aug 17, 2010 | 02:15 PM
herblatham's Avatar
well, i looked at a buddies rover, and i was able to see his level and drain plugs clear as day. So what gives, mine don't have them?
Old Aug 17, 2010 | 04:04 PM
tweakrover's Avatar
mine are barely noticably through the grease
Old Aug 17, 2010 | 07:59 PM
greg409's Avatar
Herb. go back up and re-read my post above.
My late '97 doesn't have them either
luck,greg
Old Aug 17, 2010 | 08:08 PM
Ok, heres the story...originally LR used gear lube in the swivel *****.
But people complained when they leaked.
When they were originally filled with gear lube they had oil drains.
So then they got rid of the drains and filled them with grease.
Well the grease did not lube as well if they were not kept at the proper level.
So they came up with this "00" grease, which is a mixture of grease and gear lube.
The change happened somewhere in the '96-'97 model year range.
You can make your own, or you can buy it.
I made my own, the pic I posted is what my lawnmower takes in its differential.
I made my own "00" lube in my swivel *****.
