T-stat
Old Jun 23, 2010 | 05:24 PM
tigertrakstar1's Avatar
Default T-stat
I was wondering if you guys could give me step-by-step instructions on how to change the thermostat on a 1996 land rover discovery. Illustrations would help, this is gonna be my first time attempting a repair on my own, so I'll def need someone to hold my hand. The dealership wanted to charge me 35 bucks for the t-stat plus 130 bucks for labor.
Mike in S.C.
Old Jun 23, 2010 | 06:24 PM
okdiscoguy's Avatar
It is pretty easy. It is all in the RAVE manual. It is what the dealer uses. Free download in my sig..
Old Jun 23, 2010 | 08:25 PM
fel-pro #12994
http://www.autozone.com/autozone/cat...questid=220549
Those are the parts you will need.
Have those first.
Follow the upper radiator hose from the radiator back to the top of the engine, you will find a ball with a neck on it looking thingy.
Remove it, you may need to gently tap it or pry it off with a screw driver.
Take a straight razor blade and scrap the engine and the goose neck clean and then rise with clean water and let dry.
TAKE NOTE of the direction the old t-stat is facing, install the new one the same way.
Install the new gasket, install the goose neck making sure you tighten the bolts equally.
If you tighten one side but not the other you can break the housing because it is aluminum.
Snug both bolts, top off with coolant, start the engine and check for leaks.
You may have to wait for the engine to get hot before any leaks show up.
If it leaks snug the bolts a little more.
Old Jun 23, 2010 | 09:09 PM
Spencerfitch's Avatar
kinda off topic, but that Thermostat says, 195*
Kinda high no?
Im sure its correct, just saying
Old Jun 23, 2010 | 09:14 PM
That is correct, 195*F for the DI.
180*F for the DII as it has a smaller radiator.
Old Jun 24, 2010 | 10:48 AM
discomedic4's Avatar
We could use that to tease the DII section as well lol. "my radiator is bigger than yours" lol. Sorry I couldn't resist.
thehun
Aug 23, 2011 12:24 PM
toad2
Jul 28, 2010 08:01 AM
tigertrakstar1
Jul 4, 2010 05:17 PM
tigertrakstar1
Jun 30, 2010 08:56 PM
Jawbox
Feb 8, 2009 08:41 AM
