Tachometer stopped working
Old 12-18-2010 | 08:36 PM
DiscoDad's Avatar
Default Tachometer stopped working
Tach started jumping up and own then stopped working any suggestions?
Old 12-18-2010 | 08:40 PM
Long Haul's Avatar
Alternater....Its either going bad or your wires are loose on it
Old 12-18-2010 | 09:16 PM
XCELLER8's Avatar
2x on the alternator...but as above...check the wire connections first...they're a lot cheaper !!
Old 12-18-2010 | 09:23 PM
thehun's Avatar
Altenator check your belts and pulleys. Take it to autozone anything below 13v got a bad alt. But before u change it make sure the belt is routed the right way. I had mine routed wrong it worked fine until it got cold and my alt didt have enough juice and my tach started jumping. In my case it was just a bad belt route but the tach prob was direct affect of the alt not having enough voltage. Now it's all good
Old 12-18-2010 | 09:50 PM
tweakrover's Avatar
X2 I had the exact thing happen
Old 12-19-2010 | 12:10 AM
thehun's Avatar
yep i felt like the biggest freakin idiot in the world
Old 12-19-2010 | 09:20 AM
Mark G's Avatar
My Disco's drive belt was routed incorrectly when I bought it. Same problem with my tach. Took me a lot of headscratching and rebuilding of the alternator, then finally replcing the belt before I figured it out.
Old 12-19-2010 | 09:47 AM
DiscoDad's Avatar
That was it wire with female spade connector came off the back of alternator
I ha d replaced alternator 6 months ago. Baaaa, I feel sheepish!
Old 12-19-2010 | 11:08 AM
tweakrover's Avatar
Double check your belt just for the heck of it
Old 12-19-2010 | 11:55 AM
okdiscoguy's Avatar
Can't upload from my blackberry, but the proper route is on the tech tips from roverparts.com.
Quick Reply: Tachometer stopped working
