TACometer needle not responding?
Location: Oklahoma; where the winds come rolling down the plains.
on
Upon initial startup for the day, my LRD1 GEM 4.0L tachometer needle will work intermittantly. Especially when I come to a stop. The needle will fall to around 500 rpm mark and stay there, even when I rev the engine. After a while the needle then becomes responsive and works for the rest of the day. Any thoughts on this one?
The voltage regulator inside your alt is bad, once it warms up it works fine, but until then its not putting out enough power.
If you were to check the alternators voltage when this was happening you would see that it is only putting out 11-12 volts, the battery light on the dash comes on somewhere under 12 volts.
The tach runs off of the alternator.
luxury1
04-25-2009 10:12 AM
