Hookes Joint Needle Bearings
Old Jun 25, 2009 | 09:00 PM
KeizerRover's Avatar
Default Hookes Joint Needle Bearings
While attempting to replace a universal joint on the front propeller shaft today, the Hookes Joint came apart. In trying to get it ready to put back together we found one of the needle bearings to be broken. Do the chain auto parts stores carry these little puppies? In the RAVE CD information it states that the Hookes Joint is sealed for life, but as soon as we got the faulty u-joint out the Hookes Joint came right apart.
What is the recommended solution to this? A replacement u-joint is fairly reasonably priced, but if I have to replace the entire propeller shaft to get the Hookes Joint then that is an entirely different animal.
Thanks,
Old Jun 26, 2009 | 06:19 AM
antichrist's Avatar
No and no, just get a new u-joint, Neapco 1-0005 (my preference) or Precision 344.
Old Jun 26, 2009 | 07:47 AM
Not familiar with the term of Hookes, are you referring to the u-joint or the centering ball?
Old Jun 26, 2009 | 08:39 AM
Urban Panzer's Avatar
Mike, "Hookes joint" is the term widely used in Europe for the twin UJ setup as the first known "working" version was produced by Robert Hooke in 1676, (hence the name)
A little history here for you....
http://en.wikipedia.org/wiki/Universal_joint
Old Jun 26, 2009 | 09:06 AM
Learned something new today, Thanks
Old Jun 26, 2009 | 09:46 AM
Default Needle Bearing
So, is it okay to put it all back together with one of the needle bearings in the Hooke's Joint (double cardon, double u-joint, whatever you want to call it) missing, or do I need to find a replacement? Any helpful insights on putting this stuff back together that might save me hours of trouble?
Thanks,
Old Jun 26, 2009 | 09:52 AM
I wouldn't run with one needle bearing missing.
Have you also replaced your centering ball?
Old Jun 26, 2009 | 10:07 AM
Default Centering Ball
No, I haven't gotten into that yet. What is involved with doing that? I haven't even seen that as a part anywhere. Probably wouldn't be a bad idea though.
Old Jun 26, 2009 | 01:19 PM
antichrist's Avatar
Thanks,
Did you read my reply this morning?
Also,
Hooke's Joint = u-joint
Hooke's Joint /= Double Cardon
Old Jun 26, 2009 | 09:26 PM
PalmettoDisco's Avatar
Neapco 7-0081NG or Precision 617, either brand works, is the part number for the centering ball kit.
The part is pressed in (1 inch socket fits perfectly for pressing).
Part is about $29 USD.
GeoA(Atl)07SC
Jun 2, 2010 08:35 PM
XCELLER8
Aug 27, 2009 08:15 AM
luxury1
Apr 25, 2009 10:12 AM
DISCOHAITI
Aug 27, 2007 09:09 AM
D2 2003
May 22, 2007 12:32 AM
